Troubles with images
Postby hudriwurz » Sat Oct 13, 2012 2:11 pm
Hi, I want to insert a photo (.jpg) but qcad doesn't show it. I don't know why.
There should be menue-items like 'put behind' or 'put in front'.
I don't have them (should appear under 'Modify' - Menue)
I am using qcad 2.0.5.0
I don't want to go to version 3.0.
I do have a computer, where it works?
I have no idea, why?
thanx
Emanuel
hudriwurz
Re: Troubles with images
Postby clive » Sat Oct 13, 2012 3:17 pm
Hi hudriwurz and welcome to the forum.
I assume you are using the Community Edition 2.0.5.0 - so I have moved your post to the relevant forum.
Certainly in QCAD pro versions 2 and 3 this is possible - but I am not sure about the community version (free version) as I only use the ' pro ' versions!
* Note there will be a new release of the ' free ' community edition based on QCAD 3 sometime soon in the future I believe, see here:
http://www.qcad.org/en/110-qcad-3-nearing-final-release
clive
