Surveyor Bearings
Surveyor Bearings
Postby Howard » Fri Jan 08, 2010 1:30 am
I'm new to QCAD and mostly familiar with AutoCAD and ProgeCAD. In these programs I can set units to 'surveyor units'. When I draw lines I can enter @125<N89d15'25"E to draw a line 125 feet long at this bearing. How do I accomplish the same in QCAD? Thanks.
Howard
Postby andrew » Fri Jan 08, 2010 9:43 pm
Surveyor angle input is not supported at this point in QCAD but will be most likely included in QCAD 3.
For now, you could use any mathematical formula, if that is helpful.
Postby wijit » Thu Feb 11, 2010 7:53 am
@125<89+15/60+25/3600 should give the same effect.
wijit
