Copy and paste CAD files from PDF?
Postby ive » Tue May 11, 2010 12:11 pm
Hi there, I'm trying to find out whether it's possible to send CAD files out on a PDF so that archtitects can copy and paste the files and use them? They would need access to the full files not just a flat image. Is this possible? I am new to all this, so any help would be gratefully received! Thanks
ive
Postby John.Drabik » Wed May 12, 2010 4:23 am
First day at it myself, but the answer(s) are:
1) to save a drawing as a PDF, use the File -> Export command, and select PDF from the drop-down box. Enter an appropriate name, and you're done
2) you cannot import from a PDF, near as I can tell. You'd have to get a DWG or other CAD-editable file
John.Drabik
Users browsing this forum: psbot [Picsearch] and 1 guest
