how to compile for build QCAD-2.0.5.0-1-Community Edition
Posted: Sun Jul 18, 2010 7:54 pm
How do you do All...
I am newbie, i want to compile for build QCAD-2.0.5.0-1-Community Edition.
but i have error messages like this :
Run 'make depend' to create dependencies.
test -d ./include || mkdir -p ./include
( cd ./include; rm -f *.h; \
for hf in `find ../src -name '*.h'`; do \
if [ "x$OS" = "xWindows_NT" ]; then \
cp "$hf" .; \
else \
ln -s "$hf" 2> /dev/null; \
fi \
done )
gcc -I./src -g -O2 -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DLINUX=1 -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_LIMITS_H=1 -c src/dl_writer_ascii.cpp -o src/dl_writer_ascii.o
In file included from src/dl_writer_ascii.h:35,
from src/dl_writer_ascii.cpp:34:
src/dl_writer.h: In member function ‘void DL_Writer::entityAttributes(const DL_Attributes&) const’:
src/dl_writer.h:337: error: ‘strcasecmp’ was not declared in this scope
src/dl_writer_ascii.cpp: In member function ‘virtual void DL_WriterA::dxfReal(int, double) const’:
src/dl_writer_ascii.cpp:72: error: ‘strlen’ was not declared in this scope
src/dl_writer_ascii.cpp:81: error: ‘strlen’ was not declared in this scope
src/dl_writer_ascii.cpp: In static member function ‘static void DL_WriterA::strReplace(char*, char, char)’:
src/dl_writer_ascii.cpp:147: error: ‘strlen’ was not declared in this scope
make: *** [src/dl_writer_ascii.o] Error 1
Building libdxf.a failed
What can i do for repair this error.
I have installed C & C++,GCC,Qt3,qt3-dev-tools,qt3-apps-dev,build-essential,devscripts,debhelper,dh-make,diff,patch,gnupg,fakeroot,lintian, linda,pbuilder
My Distro is Ubuntu 8.10
Regards
Thank You for All
cp "$hf" .; \
else \
fi \
done )
Regards
Thank You for All
