I have problems doing a hatch.
When I have a simple contour ( triangle, rectangle, circle, and every closed contour) it works fine, but if some line(s) are only partly on the contour (imagine something like the letter "A" for example, the triangle inside it) the hatch cant be made. So now when I have details with holes, I hatch the outer contour, then explode, then trim. It very stupid, but I havent found a better way for now.
Can somebody give an advice?
