How do I scale along one line
Postby Mesigua » Wed Nov 10, 2010 6:49 pm
The scale tool scales one object with one point as reference.
I.e. If you have a box (20x20) and you scale it with a factor of 2 you will have a 40x40 box.
I want to keep untouched one dimension line, or to scale along one line:
I.e. If you have a box (20x20) to scale it only the "y" dimension with a factor of 2, so it should create a 40x20 box.
Is this possible?
Mesigua
Postby andrew » Wed Nov 10, 2010 8:42 pm
If you have only one factor in the scale dialog, non-uniform scaling was introduced after the latest QCAD Community Edition release.
For some situations, Modify - Stretch might work.
Postby Mesigua » Wed Nov 10, 2010 11:18 pm
This is one situation where stretch doesn't work. It's a complex object.
I have the 2.0.5.0 community edition, as far as I know this is the last one, but I have one only input text box in the scale dialog.
What version do you have?
Mesigua
Postby andrew » Thu Nov 11, 2010 9:03 am
QCAD Pro (2.2) offers non-uniform scaling, at least for some simple entity types. You might want to try this with the demo:
http://www.ribbonsoft.com/qcad_downloads.html
Note that this won't change your arc entities into ellipse arcs.
Postby Mesigua » Thu Nov 11, 2010 3:45 pm
Ah, the pro version :D
I'll give it a try.
Thank you so much
Mesigua
cron
