The scale tool scales one object with one point as reference.
I.e. If you have a box (20x20) and you scale it with a factor of 2 you will have a 40x40 box.
I want to keep untouched one dimension line, or to scale along one line:
I.e. If you have a box (20x20) to scale it only the "y" dimension with a factor of 2, so it should create a 40x20 box.
Is this possible?
