Insert a building block into an OS map
Postby bluequad » Mon Feb 07, 2011 3:59 pm
I have successfully opened a DXF file of an Ordnance Survey and want to insert a building from file that I have created previously. However, having created the block of the building, it is imported at a scale hundreds of times bigger than the map although the measurements still scale the correct dimensions!
The same thing happens when copying with reference and pasting the building into the window with the map.
What am I doing wrong?
bluequad
Postby andrew » Mon Feb 07, 2011 4:05 pm
Did you check if the drawing units of both drawings match?
Postby bluequad » Mon Feb 07, 2011 4:55 pm
Thanks Andrew. I had to scale up the OS map by a factor of 1000 !
bluequad
