by garydale » Sat Aug 18, 2007 5:31 pm
This isn't a QCad issue. You can only save files to a directory where you have write access. Your home directory is one place that you should be able to save a file.
You can create or change other directories to save drawings by either making yourself a member of a group that has write access or by setting the world access (i.e. everyone) to write.
