I can select multiple text elements, but how do I change the properties of all the text elements at once? So far I'm only able to select the "Edit Text" tool and click on each text element one at a time to change things like size. Which of course makes "Select All" seem useless.
This is probably just some mouse button, click, drag thing.
It seems like there should be a way to set element properties at the layer level, is this possible?
