How do I convert between units?
Postby sneakypete » Wed Oct 10, 2007 6:45 pm
I'm a very novice user :wink: and am having a units problem when loading an existing .dxf.
This .dxf has a couple of dimensions, and when I load it in other viewers/editors, I can get these dimensions to be shown in millimeters. (eg. dimension 1 = 25.4 mm)
However whenever I open this .dxf into QCAD, the dimensions appear in inches (dimesion 1 reads as 1 inch).
What I want to do is change the numbers to be shown in milimeters. I have tried changing the units in "Current Drawing Preferences" dialog, but this just scales everything up/down, so dimension 1 still reads as 1 (but mm this time, not inches). I would like this dimension to read "25.4".
I've scoured the docs and forums, with no luck. Is there something obvious that I am missing here? I suppose I could scale the entire drawing manually, but this shouldn't be necessary, surely?
Postby michael » Wed Oct 31, 2007 11:17 pm
You can scale the drawing with "sz" (Edit, Scale Entities.) if needed.
Check this for "self-suported" help for the free community version of QCad Professional:
* Discussion Forum (new)
* Mailing List (about 650 Members, 20-50 messages per month in average)
* Join us on IRC for discussions ( / #qcad)
Do you CAD? - I do QCad.
