Can I run community edition in osx?
Postby stik69 » Sun Apr 08, 2007 7:36 pm
Very, very new to mac. I like very much what I see in the qcad demo. Can the community edition be run in osx? If so, where can I find step-by-step instructions (I'm talking very basic here) after I download it?
stik69
Re: Can I run community edition in osx?
Postby andrew » Fri May 04, 2007 9:19 am
I'm afraid but compiling sources is usually not the best solution for new users. In a nutshell, you will have to install XCode, download / compile Qt 3.3.x, set up the QTDIR environment variable, download the QCad sources and run scripts/build_qcad.sh.
stik69 wrote:Very, very new to mac. I like very much what I see in the qcad demo. Can the community edition be run in osx? If so, where can I find step-by-step instructions (I'm talking very basic here) after I download it?
Postby jalex » Mon Jun 04, 2007 2:43 am
It wouldn't be so bad if it actually compiled on OSX, as-is. If you want to compile on the mac, here's one way to get started (read to bottom):
1. Install qt3-mac from Darwin ports. You'll get an error when installing because the port has an issue where you have to set export DYLD_LIBRARY_PATH like below.
$ sudo -s
$ export DYLD_LIBRARY_PATH=/Applications/iWeb.app/Contents/Frameworks/SFRendering.framework/Versions/A/SharedFrameworks/AppleAppSupport.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources
$ port install qt3-mac.
2. Set the QTDIR variable and refresh your profile
$ echo "export QTDIR=/opt/local" >> ~/.bash_profile
$ . ~/.bash_profile
3. Now try to run the build script (./build_qcad.sh)
At this point, you should see errors starting like this:
/opt/local/include/qt3/qglobal.h:731: error: ISO C++ does not support 'long long'
/opt/local/include/qt3/qglobal.h:732: error: ISO C++ does not support 'long long'
/opt/local/include/qt3/qstring.h:435: error: 'QString QString::arg(Q_LLONG, int, int) const' and 'QString QString::arg(long int, int, int) const' cannot be overloaded
According to the link (http://lists.gobolinux.org/pipermail/go ... 04532.html) others have seen this issue with (2.0.5.0) qcad community edition from source.
It's very possible QT 3.3.4 would work, if you got the source and installed that. QT does a poor job of maintaining backward compatibility, in my experience.
Since it has a GPL license, find a programmer to fix it and submit the patches back to the qcad author or post the patches on the forum.
-J
andrew wrote:I'm afraid but compiling sources is usually not the best solution for new users. In a nutshell, you will have to install XCode, download / compile Qt 3.3.x, set up the QTDIR environment variable, download the QCad sources and run scripts/build_qcad.sh.
jalex
Postby michael » Sat Nov 17, 2007 2:06 am
Or simply buy a QCad Professional version.
Is simply the best easiest and cheap solution here.
8)
michael
cron
