Solution to Linux compile problem
Postby PhilE » Tue Jan 22, 2008 3:43 pm
Hi All:
When attempting to compile QCAD community edition on my Linux machine running Mandriva 2007.0, I was getting the same error that others had reported, namely:
ISO C++ does not support 'long long'
After a bit of Googling, I found that I could make this go away by modifying the mkspecs/ file in the directory where I had unpacked the source tarball. At the top of the file, you will see these lines:
QMAKE_CXXFLAGS += -pedantic
I commented these out, i.e. so that they now look like this:
#QMAKE_CXXFLAGS += -pedantic
I then re-ran the build script and everything worked with no further errors. Obviously, with a piece of software as complex as QCAD, there's no guarantee that this change won't break some feature or other, but at least having it compile and run without problems is a good start.
Hope this helps someone, somewhere...
Phil Edwards
Brighton, UK
Postby hpp3 » Tue Feb 19, 2008 9:44 am
Thanks for the tip. I don't know what -pedantic does, but I read somewhere that adding -Wno-long-long to your make options suppressed those errors as well.
As if I know how to do that...
Postby otiecoyote » Wed Jul 28, 2010 3:08 pm
I'm still compiling, but adding the "-Wno-long-long" text to the lines mentioned above allowed the code to compile.
I appreciate the help.
Postby rvt » Wed Aug 25, 2010 1:29 am
Compiling QCad will be simple in the near feature :
I am working on a proper fork for the Community edition of QCad, compile currently fine on OSX, Linux and Windows.
There are still issue to work out... but we are getting there!
