delete and move block insert?
Postby Sudan » Tue Jul 15, 2008 5:19 am
Newbie question:
How do I delete a insert of a block? When I try selected it I get message: "Entity must be an Atomic Entity" and it is not selected.
How do I move and rotate a insert block? When I try to select it I get the same message "Entity must be an Atomic Entity".
Thanks.
Sudan
Postby matbech » Sat Jul 19, 2008 10:58 pm
I can't understand your question... When I want to delete, move or rotate a block, I just select it with one single click and then I can delete, move or rotate it.
Maybe you can try to explode the block or redraw on the same layer (?)
matbech
