What is format for entering co-ordinates?
Postby allanmacdonald » Tue Mar 31, 2009 1:16 am
Hello folks,
I am a new user of QCAD. I am attempting to enter a 2-point rectangle using co-ordinates entered from the keyboard.
1. I set up my drawing preferences: units architectural inch.
2. I select the draw rectangle tool.
3. I select snap to grid.
4. I draw a rectangle 5 feet x 5 feet.
5. I select snap endpoints.
6. I click on the bottom left corner of the existing rectangle, setting the relative origin.
7. I then enter in the entry field labelled "Specify second corner" the following string:
@2'-4", 2'-4"
The response is "Expression syntax error".
What am I doing wrong?
Allan
allanmacdonald
Postby andrew » Tue Mar 31, 2009 10:56 am
QCAD does not understand written units (', ", mm, inch, ...) in the command line. It works purely with numbers and mathematical expressions.
To enter a relative coordinate at X: 2'-4" Y: 2'-4", please enter for example:
@28,28
or
@2*12+4,2*12+4
Postby jestal » Fri Jun 26, 2009 12:46 am
How do I enter actual values to plot my property?
Here is an example of my data from the court house.
N78 24' 50"W 524ft.
N21 41' 44"E 340ft.
jestal
