How to change colours for dimensions?
Postby beta-L-user » Sat Aug 01, 2009 1:37 pm
I created a dimension using "yellow" instead of "of layer".
Then I liked to change the colour of the dimension. This is unfortunately impossible (neither for the labels nor the dimension lines). Then I created a new one using "of Layer" and tried to change to any colour: again not possible.
For lines the same procedure works fine, but not for dimensions.
Is there a simple solution or is it a bug?
Best regards,
beta-L-user
beta-L-user
Postby Lorenzo » Sat Aug 01, 2009 5:03 pm
select all the dimensions you have to modify, then go to Modify - Attributes on the menu or 'Edit' - Attributes on CAD toolbar, specify properties to modify (layer, colour, etc.) and click OK.
Please also refer to http://www.qcad.org/qcad/manual_referen ... 28.html#16
Lorenzo
Postby beta-L-user » Sat Aug 01, 2009 7:19 pm
Thanks.
Why doesn't this work out of the menu bar?
I thought this should be the same.
Best regards.
beta-L-user
Postby Lorenzo » Sun Aug 02, 2009 10:59 am
beta-L-user wrote:Why doesn't this work out of the menu bar?
After selecting Attributes from the menu, click on the right arrow on the CAD toolbar. The 'Attributes' window will appear.
Lorenzo
