Thanks, that fixed the moc file issue.
Now to compile them...
I could use the shell script, but it does me no harm to understand the Qt build process.
Out of disk space. How typical, ha ha. Just sort that out... done. Building.
The build failed because it's trying to compile nonexistent files. The missing filenames seem to correspond to the generated moc files (for instance, there is no ui/qg_blockdialog.cpp but there is a moc/moc_qg_blockdialog.cpp).
Should I remove the nonexistent files from the build and go ahead without them? (Looks like it'd work.) Or are the missing files required?
The missing files (apologies for the length of this):
- Code: Select all
ui\qg_arcoptions.cpp
ui\qg_beveloptions.cpp
ui\qg_blockdialog.cpp
ui\qg_cadtoolbar.cpp
ui\qg_cadtoolbararcs.cpp
ui\qg_cadtoolbarcircles.cpp
ui\qg_cadtoolbardim.cpp
ui\qg_cadtoolbarellipses.cpp
ui\qg_cadtoolbarinfo.cpp
ui\qg_cadtoolbarlines.cpp
ui\qg_cadtoolbarmain.cpp
ui\qg_cadtoolbarmodify.cpp
ui\qg_cadtoolbarpoints.cpp
ui\qg_cadtoolbarselect.cpp
ui\qg_cadtoolbarsnap.cpp
ui\qg_circleoptions.cpp
ui\qg_commandwidget.cpp
ui\qg_coordinatewidget.cpp
ui\qg_dimlinearoptions.cpp
ui\qg_dimoptions.cpp
ui\qg_dlgarc.cpp
ui\qg_dlgattributes.cpp
ui\qg_dlgcircle.cpp
ui\qg_dlgellipse.cpp
ui\qg_dlghatch.cpp
ui\qg_dlgimageoptions.cpp
ui\qg_dlginitial.cpp
ui\qg_dlginsert.cpp
ui\qg_dlgline.cpp
ui\qg_dlgmirror.cpp
ui\qg_dlgmove.cpp
ui\qg_dlgmoverotate.cpp
ui\qg_dlgoptionsdrawing.cpp
ui\qg_dlgoptionsgeneral.cpp
ui\qg_dlgpoint.cpp
ui\qg_dlgrotate.cpp
ui\qg_dlgrotate2.cpp
ui\qg_dlgscale.cpp
ui\qg_dlgtext.cpp
ui\qg_exitdialog.cpp
ui\qg_imageoptions.cpp
ui\qg_insertoptions.cpp
ui\qg_layerdialog.cpp
ui\qg_libraryinsertoptions.cpp
ui\qg_librarywidget.cpp
ui\qg_lineangleoptions.cpp
ui\qg_linebisectoroptions.cpp
ui\qg_lineoptions.cpp
ui\qg_lineparalleloptions.cpp
ui\qg_lineparallelthroughoptions.cpp
ui\qg_linepolygon2options.cpp
ui\qg_linepolygonoptions.cpp
ui\qg_linerelangleoptions.cpp
ui\qg_mousewidget.cpp
ui\qg_moverotateoptions.cpp
ui\qg_printpreviewoptions.cpp
ui\qg_roundoptions.cpp
ui\qg_selectionwidget.cpp
ui\qg_snapdistoptions.cpp
ui\qg_textoptions.cpp
ui\qg_trimamountoptions.cpp
ui\qg_widgetpen.cpp
