Command line history
Postby mick » Thu Jul 24, 2008 4:11 pm
Is there a way of reducing the number of lines in the command line history window, or just keep a basic command line without it? It seems to use a lot of valuable screen estate. Also, can it be shorter, to allow the blocks menu to be longer?
mick
Postby andrew » Thu Jul 24, 2008 4:32 pm
No, there is no way to reduce its size. However, you can hide it, or detach it from the application window or move the block widget or another widget beside it. It is also possible to attach it at the side, for example below the layer list which makes it really small.
Return to Pre-sales Questions
