2 questions about the use of blocks
Postby ggsalas » Sat Feb 07, 2009 1:09 am
I have 2 questions about the use of blocks:
1 - Is there a way to edit a block in the same plane? (not to be opened in a new window)
2 - Is there a way to change the color of a block? (although the lines are colored "by layer")
ggsalas
Re: 2 questions about the use of blocks
Postby andrew » Mon Feb 09, 2009 9:09 am
ggsalas wrote:Hello,
No
ggsalas wrote:2 - Is there a way to change the color of a block? (although the lines are colored "by layer")
No. You would have to set the color of the block entities to "ByBlock" for this.
Postby ggsalas » Mon Feb 09, 2009 1:31 pm
No
Sorry for my insistence.
Is there a list of changes planned for the next version?
Thanks,
Gabriel.
ggsalas
Return to Pre-sales Questions
