Areas
Areas
Postby LuisC-SM » Wed May 16, 2007 7:08 pm
Hi.
This cuold be a very stupid question, but before buying I'd like to know 2 things.
1. When drawing a polygon; let's say a rectangle, will I be able to establish the lines measurements?
2. Is there a way to automatically get the area?
eg: I draw a rectangle which measuremets are 3 M wide and 6 M large, the obvious area result should be 18 square meters.
Thanks for your response.
Luis
LuisC-SM
Re: Areas
Postby andrew » Sun May 20, 2007 9:25 pm
LuisC-SM wrote:1. When drawing a polygon; let's say a rectangle, will I be able to establish the lines measurements?
Yes, you would usually do that with the dimensioning tool. Dimensions are drawing elements that show for examples the length of a line.
See also:
http://www.ribbonsoft.com/qcad/manual_reference/chapter24.html
LuisC-SM wrote:2. Is there a way to automatically get the area?
No, not fully automatically. You would have to use the tool 'Info' - 'Polygonal Area' and then click the four corners of your rectangle.
See also:
http://www.ribbonsoft.com/qcad/manual_reference/chapter29.html#5
Postby LuisC-SM » Mon May 21, 2007 5:59 pm
Thanks.
Enough for me to buy the product.
Kind Regards
Luis
LuisC-SM
Return to Pre-sales Questions
