by diego.gnesi » Thu May 17, 2012 1:03 pm
I inherited a class from DL_CreationAdapter for extracting layer names from a dxf file. The problem is that the code is VERY slow, because the DL_CreationAdapter correctly reads all layers but then contnues to read the file until the end. Is there a method to stop parsing when layers' data are all red?
diego.gnesi
by andrew » Mon May 21, 2012 4:12 pm
No.
You could add add that functionality to DL_CreationInterface as follows:
dl_creationinterface.h:
- Code: Select all
// implement this in your creation interface implementation to return true to stop parsing
bool DL_CreationInterface::stop() = 0;
dl_creationadapter.h:
- Code: Select all
bool DL_CreationInterface::stop() {}
dl_dxf.cpp:
- Code: Select all
DL_Dxf::in(...) {
while (readDxfGroups(fp, creationInterface, &errorCounter) && !creationInterface->stop()) {}
