How to draw text with the dxf->writeText()
Posted: Thu Jan 13, 2011 3:04 pm
Hello!
I have a question. How to use dxf->writeText(...)
In *.dxf file I draw only one text string with dxf->writeText()
AutoCad (2000, 2002, 2004, 2005) error:
if DL_Codes::AC1009; all is alright, but not support Layers styles and other (AutoCad 11/12)
I use VS2008 with MFC librory
thanks in advance.
dxflib is great work, really nice code. Thanks the author!
my code:AutoCad 2005
The following error was encountered while reading
in TEXT starting at line 1518:
Unexpected DXF group code: 73
Invalid or incomplete DXF input -- drawing discarded.
DL_Codes::version exportVersion = DL_Codes::AC1015;
dxf->writeText(
*dw,
DL_TextData(
0.0,//X Coordinate of insertion point
0.0,//Y Coordinate of insertion point.
0.0,//Z Coordinate of insertion point.
100.0,//X Coordinate of alignment point
0.0,//Y Coordinate of alignment point
0.0,//Z Coordinate of alignment point
2.5,//Text height
1.0,//Relative X scale factor.
0,//0 = default, 2 = Backwards, 4 = Upside down
0,//Horizontal justification 0 = Left (default), 1 = Center, 2 = Right,3 = Aligned, 4 = Middle, 5 = Fit
0,//Vertical justification. 0 = Baseline (default), 1 = Bottom, 2 = Middle, 3= Top
"some text",// Text string.
"Standard",//Style (font).
0),//Rotation angle of dimension text away from default orientation.
DL_Attributes("mainlayer",256,-1,"BYLAYER"));
thanks in advance.
