QCad PDF export creates huge files
ringstrom
Postby ringstrom » Mon Sep 03, 2007 8:28 pm
For a drawing that uses splines, e.g. by using the standard font, the exported PDF files are huge. I found a way to work around that in Linux. If the files are printed to a (PDF) file in Linux, the files are much smaller. For the two of my drawings that I checked, which both contain a moderate amount of text, the difference is 573% and 657%, respectively.
The reason for the difference comes from the fact that the printed, small, PDF:s contain splines, but the PDF:s exported via the PDF export function in QCad only contain straight lines, so each spline in the drawing is represented by a large number of straight lines.
Another drawback of the large PDF:s, apart from size alone, is that they take much longer to display and print.
I'm using QCad Professional version 2.1.3.2 on both Linux and Windows.
michael
Postby michael » Fri Nov 02, 2007 4:52 pm
Yes, this depends on the PDF Export implementation the toolkit use. It is maybe better in Linux then Windows.
Maybe linked to different versions of Qt (from trolltech.com)
Do you CAD? - I do QCad.
Return to “QCAD 2.1/2.2 Suggestions and Feedback”
