Dimension layer text sizes
Postby wschwab » Tue Dec 04, 2007 9:37 pm
Would it be possible to size dimension text, offsets, etc., by layer rather across an entire drawing? An adjustable drawing-wide default set would be great, but overrides or a scale factor per layer would be a big boost. I use QCad to draw everything from small pins up to an entire (at the risk of overstating matters) an entire machine/device/enclosure. Sizes vary by a factor of ten, sometimes more, making one text size restrictive.
Bill
wschwab
Postby michael » Thu Dec 13, 2007 9:47 pm
I know the problem but I think the problem is still open. As far as I know it is not possible to define a "text / dimension-text size by layer".
Do you CAD? - I do QCad.
michael
