QtJSAPI usage
QtJSAPI usage
Post by andrew » Mon Nov 13, 2023 10:45 am
From a developer:
Can I expose an already existing QMainWindow and access all its children from a .js script?
Re: QtJSAPI usage
Post by andrew » Mon Nov 13, 2023 10:54 am
Yes. You can expose existing QObject objects as you normally would:
QJSEngine* engine = new QJSEngine();
RJSApi* rjsapi = new RJSApi(engine);
// this makes the Qt classes known to the script engine:
rjsapi->init();
QJSValue global = engine->globalObject();
global.setProperty("appWin", engine->newQObject(appWin));
QQmlEngine::setObjectOwnership(appWin, QQmlEngine::CppOwnership);
In JS, you can then use:
var w = appWin.findChild('NameOfChild');
or for example:
var children = appWin.children();
