changing the lineweight of an entity.
mrhickman53
Post by mrhickman53 » Wed Mar 27, 2024 9:11 pm
Version:
3.29.4.0 (3.29.4)
Internet:
QCAD.org
Build Date:
Feb 7 2024
Revision:
36a6423
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
I am trying to change the lineweight of several entities, starting with the circle described below. The debug statement indicates the lineweight is being changed but the circle gets added to the document with RLineweight.ByLayer. What am I missing?
Thanks.
    circleEntity = shapeToEntity( this.doc, mycircle );
    circleEntity.setLineweight( RLineweight.Weight100 );
    qDebug( 'circleEntity.getLineweight() = ', circleEntity.getLineweight(), circleEntity.getLineweight() == RLineweight.Weight100 );
    op.addObject( circleEntity );
    //op.addObject( shapeToEntity(this.doc, circle) );
    op.addObject( myleaderEntity );
    //op.addObject( leaderEntity );
    this.di.applyOperation(op);
Re: changing the lineweight of an entity.
Post by andrew » Wed Mar 27, 2024 10:21 pm
RAddObjectsOperation::addObject uses the current attributes by default. You can disable this default behaviour by passing false as second argument (useCurrentAttributes):
op.addObject(circleEntity, false);
mrhickman53
Post by mrhickman53 » Thu Mar 28, 2024 12:15 am
Thanks. I did not understand the use of the "current attributes" flag.
Post by CVH » Thu Mar 28, 2024 8:03 am
mrhickman53,
If considered as solved then please add [Solved] to the title of your initial post by editing it.
