Update a table when user switches between opened tabs
Postby s4eed » Tue Apr 15, 2014 7:45 pm
Hi everyone.
I created a program based on the QCad Application framework that has a QTableWidget in a QDockWidget. I need to update contents of this table when user switches between opened files in the application. How can I be informed that user has selected a new tab in MDI area?
s4eed
Re: Update a table when user switches between opened tabs
Postby andrew » Tue Apr 15, 2014 7:56 pm
Creating a focus listener class:
function MyFocusListener() {
RFocusListenerAdapter.call(this);
MyFocusListener.prototype = new RFocusListenerAdapter();
MyFocusListener.prototype.updateFocus = function(documentInterface) {
// this will be called whenever the user switched to another document
// documentInterface may be undefined if no document is open (last document was closed)
// in this case, a widget is typically cleared
Installing the focus listener:
var appWin = EAction.getMainWindow();
var fl = new MyFocusListener();
appWin.addFocusListener(fl);
Postby s4eed » Sun Apr 20, 2014 11:30 am
Thanks but I got this error :
RMainWindow: Argument 0 is not of type RViewFocusListener *RViewFocusListener *.
s4eed
Postby andrew » Sun Apr 20, 2014 12:05 pm
Sorry, the last line should be:
(I've also corrected this in the previous post to avoid confusion for other readers).
Return to QCAD 3 Developers and Contributors
