Removing an image entity
s4eed
Postby s4eed » Tue May 13, 2014 8:51 am
Hello dear friends.
I add an image entity to my map using this code :
   var i = new RImageEntity(
      document,
          new RImageData("scripts/MyScripts/tick.png",
                     new RVector(0,0),
                     new RVector(1,0),
                     new RVector(0,1),
                     50, 50, 0)
   documentInterface.setRelativeZero(point);
   i.setWidth(2);
   i.setHeight(2);
   i.setInsertionPoint(point);
   TickImageEntites[entId] = i;
Suppose that entId is a unique key associated to each ImageEntity and TickImageEntites is something like this :
var TickImageEntites = {};
Then I want to remove all of this image entities inside TickImageEntites using this code :
      for (var k in TickImageEntites) {
         QMessageBox.information(0,"msg", "id:"+k);
         var op = new RDeleteObjectOperation(TickImageEntites[k], false);
                        di.applyOperation(op);
But my code doesn't work at all! What the problem. thanks.
Re: Removing an image entity
Postby andrew » Tue May 13, 2014 11:18 pm
You might want to print TickImageEntites[k] in your for loop, to check if these are valid entities with a valid ID, etc.
Return to “QCAD 3 Developers and Contributors”
Users browsing this forum: No registered users and 5 guests
