? [solved] Add custom property in library item script
Postby spatz » Fri May 16, 2014 9:35 am
I wrote a library item script for inserting drawings of steel sections in several sizes according to DIN standard. Now I want to add a custom property to the (polyline) entity using the .setProperty() method like it's shown here https://ribbonsoft.com/rsforum/viewtopic.php?p=4552.
But when I add this code (line 89/90 in attached file "StructuralSteelSectionsI.js")
   var des = "DIN 1025-1" + " - " + "I " + StructuralSteelSectionsI.hi ;
   polylineEntity.setProperty(new RPropertyTypeId("designation"), des);
there's nothing shown in the property editor and I get the following error message:
Warning:  RObject::setProperty:  cannot set custom property with empty title or name
I printed the content of variable "des" with "qdebug(des)" and it showed the right value. Changing the color using
polylineEntity.setColor(new RColor("blue"));
worked, so I guess the variable "polylineEntity" is also a correct Entity object. What did I miss?
Best regards
Stephan
Edit:
I'm using QCAD version 3.5.1.0 on Linux Mint Debian (32bit)
StructuralSteelSectionsI.ui
(2.78 KiB) Downloaded 64 times
(4.33 KiB) Downloaded 67 times
spatz
Re: ? Add custom property in library item script
Postby hungerburg » Sat May 17, 2014 2:33 pm
Hello Spatz, the post you refer to is three years old. The interface did change since then. Discussion and up to date sample code here http://www.qcad.org/bugtracker/index.ph ... omment1239 and documentation here http://www.qcad.org/doc/qcad/3.0/develo ... 908190d766
Basically, setCustomProperty() takes three parameters, thats the complaint you receive.
hungerburg
Senior Member
Re: ? [solved] Add custom property in library item script
Postby spatz » Sat May 17, 2014 10:29 pm
Hello hungerburg,
thank you for your quick reply. Replacing setProperty() with setCustomProperty() and using three parameters indeed solved my problem (see updated script attached).
Best regards
Stephan
(4.52 KiB) Downloaded 73 times
spatz
Postby hungerburg » Tue May 20, 2014 12:16 pm
Hello Spatz, I copied the script to the library and can see the I-beam in the browser, but I cannot put it into a drawing. What else would I have to do for that?
hungerburg
Senior Member
Postby spatz » Tue May 20, 2014 6:32 pm
Hello Hungerburg,
did you also download the .ui file in my first post? I didn't upload it again because I hadn't changed it since.
Best regards
Stephan
spatz
Return to QCAD 3 Developers and Contributors
