QCAD Plugins: Using different compiler / Qt version
Postby andrew » Mon May 19, 2014 9:30 am
From a QCAD user:
Do we need to build our C++ plugins using the same version of QT and compiler (mvc10 in this case) as you built qcad with?
Re: QCAD Plugins: Using different compiler / Qt version
Postby andrew » Mon May 19, 2014 9:33 am
You can find some information about mixing Qt versions at:
http://qt-project.org/doc/qt-4.8/deploy ... ugins.html
MinGW has some information about mixing compilers:
http://www.mingw.org/wiki/MSVC_and_MinGW_DLLs
Using the same compiler and Qt version is certainly the preferred option if you have a choice.
Postby andrew » Wed Aug 27, 2014 9:32 am
Note: I've split your last post about making classes scriptable into a new thread at:
viewtopic.php?f=30&t=3022
Return to QCAD 3 Developers and Contributors
