QCAD Compilation from source fatal error U1077
Postby jays » Fri May 23, 2014 2:15 pm
Hi there,
I'm trying to compile QCAD from the source so I can build it for msvs2008. I've been following the instructions given here: http://www.qcad.org/en/component/conten ... om-sources.
I've managed to successfully configure and compile Qt 4.8.5 and I set my environment variable PATH to the bin correctly. I created a new environment variable QMAKESPEC and set the value to win-32-msvc2008. I completed the configuration of QCAD without any problems. However, about 30 min into the compilation I've run into the following error: NMAKE : fatal error U1077: 'cd' :return code '0x2'. I've seen similar errors reported for the compilation of Qt, however, I had no problem there. Is there anyone who has any idea what may be wrong? Thanks in advance.
Generating Code...
c:\qcad\src\3rdparty\qt-labs-qtscriptgenerator-4.8.5\generated_cpp\com_trolltech_qt_webkit\qtscriptshell_qwebpluginfactory.cpp(58)
: warning C4715: 'QtScriptShell_QWebPluginFactory::create' : not all control paths return a value
c:\qcad\src\3rdparty\qt-labs-qtscriptgenerator-4.8.5\generated_cpp\com_trolltech_qt_webkit\qtscriptshell_qwebpluginfactory.cpp(128)
: warning C4715: 'QtScriptShell_QWebPluginFactory::plugins' : not all control paths return a value
_qt_webkit\qtscriptshell_qwebhistoryinterface.cpp(105)
: warning C4715: 'QtScriptShell_QWebHistoryInterface::historyContains' : not all control paths return a value
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\BIN\nmake.exe"' : return code '0x2'
Stop.
NMAKE : fatal error U1077: 'cd' : return code '0x2'
Stop.
Stop.
Stop.
Stop.
Stop.
C:\qcad>
jays
Return to QCAD 3 Developers and Contributors
Users browsing this forum: Yahoo [Bot] and 2 guests
