Is it possible to make custom properties read-only
Taygete
Postby Taygete » Sat May 31, 2014 4:12 pm
I have done a search and haven't been able to find this feature.
I currently set some custom properties in a script which the user can then view and change in the property editor, however there is some data I would like to make read-only so the user cannot change it.
Ideally I would like to be able to set a flag when setting the custom property to be read-only (or another choice might be to make it visible/hidden in the property editor), is this possible?
Thanks,
Andrew.
hungerburg
Re: Is it possible to make custom properties read-only
Postby hungerburg » Sat May 31, 2014 7:40 pm
Not an authoritative answer, but I studied xdata in the dxf spec and there is no such flag there. As dxf is the standard file format in qcad such a feature would require a proprietary extension.
Taygete
Postby Taygete » Sun Jun 01, 2014 6:00 am
hungerburg wrote:Not an authoritative answer, but I studied xdata in the dxf spec and there is no such flag there. As dxf is the standard file format in qcad such a feature would require a proprietary extension.
Hi hungerburg,
Thanks for the info, I guess that is why there isn't this option already.
Andrew.
hungerburg
Postby hungerburg » Tue Jun 03, 2014 10:19 am
You could put the data that you want to hide from the users below a different APPID than the one users are to modify themselves, so there is at least some visual separation.
Taygete
Postby Taygete » Tue Jun 03, 2014 3:26 pm
hungerburg wrote:You could put the data that you want to hide from the users below a different APPID than the one users are to modify themselves, so there is at least some visual separation.
Hi hungerburg,
Thanks for the idea, I will take a look into that.
Andrew.
Postby andrew » Thu Jun 05, 2014 8:38 am
There's definitely some room for improvement for the handling of custom properties.
QCAD stores custom properties as strings in the format 'key:value".
This notation is entirely QCAD specific and could be extended to contain other information such as:
ReadOnly,                  // Property is read only
Invisible, // Property is not displayed
Angle, // Property is an angle (shown in user preferred angle unit)
RichText, // Property is rich text and can be edited as such
Style, // Property is a text style (font)
Label, // Property is a label (suggests context menu to insert symbols)
Pattern, // Property is a hatch pattern name
Integer, // Property is an integer number
Double, // Property is a double (real) number
Boolean, // Property is a boolean (true or false)
List // Property is one of several choices presented in a combo box
And possibly others. Any thoughts?
Taygete
Postby Taygete » Thu Jun 05, 2014 4:46 pm
andrew wrote:There's definitely some room for improvement for the handling of custom properties.
Hi Andrew,
All those on your list are good ideas, the readonly and invisible are particularly interesting to me.
I will have a think on this and if I come up with any questions or further ideas will post back.
Thanks,
Andrew.
Return to “QCAD 3 Developers and Contributors”
