Load two or more DXF files into one View and do layout
Postby wang » Wed Jun 11, 2014 8:46 am
I am a new one to QCAD. And I am trying to do some work about load and display DXF file.
This post about "Loading and Displaying DXF file" helps a lot.
But what I need is to load two or more dxf files into one view and do layout work automatically, after that save the result as a new dxf file.
I have checked the API documents, but because I am newer here , I found nothing.
Is there someone kind enough to give me some script sample about that?
Thanks a lot!
wang
Re: Load two or more DXF files into one View and do layout
Postby andrew » Wed Jun 11, 2014 9:16 am
Hello Wang,
Please have a look at this script command line tool which merges multiple DXF/DWG files based on a simple XML input file:
https://github.com/qcad/qcad/blob/maste ... rawings.js
Actually, if you only need to merge drawings without displaying, etc, you might be able to use this tool out of the box. The XML format is:
input.xml:
<?xml version="1.0" encoding="UTF-8"?>
<merge xmlns="http://qcad.org/merge/elements/1.0/" unit="Millimeter">
<item src="myfile001.dxf">
<insert x="0" y="0" angle="15" scale="1.2" flipx="true" flipy="false" />
<insert x="50" y="0" />
</item>
<item src="myfile002.dxf">
<insert x="100" y="50" angle="30" />
</item>
</merge>
This would merge the files myfile001.dxf and myfile002.dxf into output.dxf:
./merge -o output.dxf -f input.xml
The tool is currently available in our git repository only, but will be included in the next QCAD release.
Postby wang » Thu Jun 12, 2014 3:04 am
The source is great.
I found that the source you gave, the paste operation do the work to merge two dxf files, that is good sample of know-how.
The positions and angles was pre-defined in XML file.
Should the position and angle be determined by user interactive operation or layout automatically positions calculated.
Another question is if two files were merged, could I still operate the dxf individually, such as drag to move or rotate the objects in one dxf file together to do layout work manully.
wang
Postby andrew » Thu Jun 12, 2014 8:25 am
wang wrote:Should the position and angle be determined by user interactive operation or layout automatically positions calculated.
You could simply use the QCAD Library Browser for this (View > Library Browser). It allows you to drag items form the part library into an empty drawing to merge them.
Yes, the items are inserted as block references ('grouped') with block name = file name (myitem001.dxf creates block 'myitem001').
Return to QCAD 3 Developers and Contributors
