Trying to use REntity intersectsWith()
Postby Taygete » Tue Jul 15, 2014 4:42 pm
Hi Andrew,
I have written some code (C++) to locate intersecting entities in the drawing.
The code runs fine with no errors however REntity::intersectsWith(...) always returns false even if there are entities that intersect.
I am testing with a PolyLine and Circle in the drawing, the entities are on different layers however I have also moved them onto the same layer with the same false result.
Any ideas?
Thanks,
Andrew.
Taygete
Re: Trying to use REntity intersectsWith()
Postby andrew » Tue Jul 15, 2014 5:05 pm
Try rebuilding the spatial index before your query:
document->rebuildSpatialIndex();
If you import entities from a file using an existing file importer or if you add entities using operations or transactions, this is not necessary.
However, there are also ways to add entities to a document or storage bypassing the spatial index. In this case, you will have to rebuild the index when you're done.
You can also dump the spatial index for debugging:
qDebug() << document->getSpatialIndex();
Postby Taygete » Tue Jul 15, 2014 6:07 pm
andrew wrote:Try rebuilding the spatial index before your query:
Hi Andrew,
Thanks for the quick response.
I tried rebuilding the spatial index but this still didn't work, I will try sending the info to qDebug() to see what that reveals.
Will intersectsWith() work with items on different layers?
Thanks,
Andrew.
Taygete
Postby andrew » Tue Jul 15, 2014 8:34 pm
Taygete wrote:Will intersectsWith() work with items on different layers?
Yes. Perhaps you can post the relevant section of the code, so I can help more efficiently.
Postby Taygete » Wed Jul 16, 2014 1:31 pm
Hi Andrew,
Sorry for the late reply, I have been in meetings all morning but will post again shortly with the relevant code.
Thanks,
Andrew.
Taygete
Postby Taygete » Wed Jul 16, 2014 2:31 pm
Hi Andrew,
Please find the code below with comments. Basically I am allowing users to drop a Library script onto a drawing, there are three scripts, two create polyline shapes and the third creates a circle. Each script creates custom properties.
Once the user has dropped the items onto the drawing to build up a plan they then click a menu item to call into my c++ plugin where I check for intersections.
Basically I need to search the drawing for all entities which have a specific custom property (in this case "JunctionType"), the shape is a circle so I build up a QList<REntity::Id> of these entities.
Here is that specific code which does build up a list of the correct type.
// Create a list of junction types.
QList<REntity::Id> junctionList;
// Rebuild the index
doc.rebuildSpatialIndex();
// Get a list of RS::EntityPolyline and RS::EntityCircle as these are the only items we are
// interested in when dropping the modules onto the current drawing
QSet<REntity::Id> entities = doc.queryAllEntities(false, false);
// Get a list of junction entities
foreach (REntity::Id entity, entities)
// Get the entity for this id
QSharedPointer<REntity> theEntity = doc.queryEntity(entity);
// Check for null and continue if it is null
if (theEntity.isNull()) {
continue;
// Get the list of properties for the QCAD title
QStringList properties = theEntity->getCustomPropertyKeys("QCAD");
// Make sure we have some custom properties for this item
if (properties.count() > 0)
// Loop through the list of keys for each entity and add to our list
foreach (QString property, properties)
if (property.contains("JunctionType"))
junctionList.append(theEntity->getId());
break;
I then research the entity list looking for intersections between a found junction item(s) and other entities, this is the part which always fails and I have debugged the code through the QCad intersectWith code but it doesn't find the intersection.
Here is that specific code which does looks for intersections.
// Using our list loop back through and see if each item is intersecting
// with another entity
foreach (REntity::Id j, junctionList)
QSharedPointer<REntity> theJ = doc.queryEntity(j);
if (theJ.isNull()) {
continue;
//Get a list of junction entities
// Check for null and continue if it is null or the two entities are
// the same object
if (theEntity.isNull() || theEntity == theJ) {
continue;
// Get the intersection
bool bIntersected = theJ->intersectsWith(*theEntity->castToConstShape());
// We have found an intersect.
if (bIntersected == true)
// For debuging in release build
QMessageBox::information(NULL, "Found an intersect", "The junction has intersected with another entity");
Any help would be much appreciated.
Thanks,
Andrew.
Taygete
Postby andrew » Wed Jul 16, 2014 9:43 pm
I'd suggest to print theJ and theEntity to check if these are as expected:
qDebug() << "theJ: " << *theJ;
qDebug() << "theEntity: " << *theEntity;
The call to intersectsWith seems to be fine. No spatial index is required for this direct query.
Postby Taygete » Thu Jul 17, 2014 1:35 pm
andrew wrote:I'd suggest to print theJ and theEntity to check if these are as expected:
Having trouble at the moment getting qDebug() to work, it isn't outputting anything.
Andrew, would it be okay if I pm you a test file to look at and confirm intersectsWith is what I should be using, more a sanity check on my part.
Thanks,
Andrew.
Taygete
Postby Taygete » Thu Jul 17, 2014 3:01 pm
Hi Andrew,
Finally got the entities printed out and they look fine to me.
I have pm'd you the output and also the dxf which the entites are from, would you please have a quick look over them to make sure they are okay and intersectWith is indeed the correct method to use?
Thanks,
Andrew.
Taygete
Postby Taygete » Thu Jul 17, 2014 4:19 pm
Hi Andrew,
After having no luck with the REntity::intersectsWith(...) method I started investigating other possibilities.
I am now getting the bounding box of the two entities I am comparing then calling RBox::intersects(...), this seems to be working.
I assume there is no downside to using this method over the REntity::intersectsWith(...) one?
Thanks,
Andrew.
Taygete
Postby andrew » Thu Jul 17, 2014 4:55 pm
Taygete wrote:I am now getting the bounding box of the two entities I am comparing then calling RBox::intersects(...), this seems to be working.
The results will be different.
The bounding boxes of two for (example parallel) lines may intersect even though the lines don't.
If you have a debugger handy, steping through the code should quickly reveal what the problem is.
Return to QCAD 3 Developers and Contributors
cron
