Where to do some clean up stuff while file is being closed?
Postby s4eed » Tue Jul 22, 2014 9:44 am
I'm developing my own app based on QCad application framework.
I want to close the database connection, clean up some widgets and do some other clean up stuff while a document is being closed in my program. Where should do these kind of works.
s4eed
Re: Where to do some clean up stuff while file is being clos
Postby andrew » Wed Jul 23, 2014 1:53 pm
I've added an appropriate signal to RMdiChildQt.
The signal is emitted just before a document is definitely closed (closeAccepted):
https://github.com/qcad/qcad/commit/f8d ... 7360ce1adc
If you pull the latest master branch, you can update immediately. Otherwise, you'd have to wait for the upcoming 3.6.3 release.
Return to QCAD 3 Developers and Contributors
cron
