Zoom Cursor
PiperPilotJohn
Zoom Cursor
Post by PiperPilotJohn » Wed Mar 16, 2016 4:57 am
Is there a way to change the cursor from the regular "arrow cursor" to, say, a magnifying glass or some other symbol when in Window Zoom mode? I can't tell you the number of times I've accidentally zoomed the drawing when I was actually trying to use the cursor to make a selection. The standard "arrow" (what I'll call the selection cursor - i.e. when no other mode is selected) is exactly the same cursor used when Window Zoom is active. Thanks.
Re: Zoom Cursor
Post by andrew » Wed Mar 16, 2016 8:52 am
This should indeed be the case but appears to be broken in the current release. I've issued a bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1396
PiperPilotJohn
Re: Zoom Cursor
Post by PiperPilotJohn » Wed Mar 16, 2016 11:53 pm
Thanks Andrew!
PiperPilotJohn
Re: Zoom Cursor
Post by PiperPilotJohn » Mon Mar 21, 2016 1:17 am
Cursor is fixed in the latest release!!! Thanks Andrew!!!
