[Solved] How dwg2bmp -r option is used
Use this forum to ask questions about how to do things in QCAD version 3.1/3.0
Postby JJK » Thu Nov 29, 2012 7:38 am
How dwg2bmp -r option is used?
I have tried this:
/home/user/opt/qcad/dwg2bmp -b white -f -r 10 -o /home/www/7194.png /home/www/7194.dxf
I'll just get an error:
dropped global XDATA (no value): "CadsVariable_INSSCALE"
size: 353 x 429
/home/user/opt/qcad/qcad-trial: rivi 36: 12024 Memory area crossing (created a core file) LD_LIBRARY_PATH="$DIR" "$binary" $OPT1 $OPT2 "$@"
JJK
Re: How dwg2bmp -r option is used
Postby andrew » Thu Nov 29, 2012 9:15 am
The command seems correct and the size is reasonable.
Does QCAD itself work as expected on your system?
Can you try to convert the examples drawings, e.g.:
cd /home/user/opt/qcad
./dwg2bmp -o test.png ./examples/flange.dxf
If the examples work as expected, the problem is likely related to the drawing file. Please send us the file for testing in this case if possible, thanks.
Postby JJK » Thu Nov 29, 2012 10:59 am
This gives the same error:
/home/user/opt/qcad/dwg2bmp -o /home/www/test.png /home/www/test.dxf
if I use "-x 300 -y 300" so it works well
test.dxf
(51.81 KiB) Downloaded 90 times
JJK
Postby JJK » Tue Dec 04, 2012 5:42 am
Now I tested Windows 7
But I can not find any file conversion. :(
C:\Program Files (x86)\QCADTrial>dwg2bmp.bat -f -r 10 examples/flange.dxf
size:  1534 x 1320
C:\Program Files (x86)\QCADTrial>dwg2bmp.bat -o C:/Users/User/Desktop/flange.bmp examples/flange.dxf
I needed very much for such a program. So I would be very grateful if this could get to work. :)
JJK
Postby andrew » Tue Dec 04, 2012 9:37 am
Please note that Windows uses backslashes (\) to separate directories and file names in paths.
You might want to run the application without the batch file to see the output log:
qcad-trial.exe -no-gui -autostart scripts\Tools\Dwg2Bmp\Dwg2Bmp.js -o C:\Users\User\Desktop\flange.bmp examples\flange.dxf 1>log.txt 2>&1
After that, have a look at the file log.txt for the program output.
Postby JJK » Tue Dec 04, 2012 9:48 am
log.txt is empty and i can not find flange.bmp image in desktop :(
JJK
Postby andrew » Tue Dec 04, 2012 9:53 am
Does the QCAD application work on your system?
How about:
qcad-trial.exe -no-gui -autostart scripts\Tools\Dwg2Bmp\Dwg2Bmp.js -h 1>log.txt 2>&1
This should output usage information.
Postby JJK » Tue Dec 04, 2012 10:12 am
QCAD works well.
This create empty log.txt file
Edit:
While I waited longer log.txt included such
Usage: -h [OPTIONS]... <drawing file>
Converts a DWG / DXF file to a Bitmap file.
  -a, -antialiasing       Enable antialiasing
  -b, -background=C       Set the background color as color name
                          e.g. 'white' or '#ccdd00'.
  -f, -force              Overwrite existing output file
  -h, -help               Display this help
  -l, -list               List supported formats
  -m, -margin=M           Set auto zoom margin to M (in pixels)
  -o, -outfile=FILE       set output file to FILE
                          default is same path and base name as input file
  -q, -quality=Q          Set the image quality / compression
                          (0=best compression..100=best quality)
  -r, -resolution=R       Set rendering resolution to R
                          (in pixels/drawing unit)
                          This overrides the width/height parameters.
  -x, -width=W            Set bitmap width to W (in pixels)
  -y, -height=H           Set bitmap height to H (in pixels)
  -p, -origin             Draw zero point (origin)
JJK
Postby andrew » Tue Dec 04, 2012 10:37 am
I cannot reproduce this problem here at the moment, but I've filed a bug report at:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=733
Postby JJK » Mon Dec 10, 2012 5:16 am
OK. Thanks.
Do you know of something that works with Linux.
JJK
Re: [Solved] How dwg2bmp -r option is used
Postby JJK » Mon Jan 21, 2013 7:59 am
This seems to work 3.0.3 (Linux) version.
:P
JJK
Return to QCAD 3.1/3.0 'How Do I' Questions
