How Do I generate a QCAD using QCAD source code
725411314qi
Post by 725411314qi » Fri Dec 05, 2014 10:34 am
I want to use the QCAD source code in order to generate the QCAD(espically the QCAD.exe file).I can not use the source code well.HELP!
Re: How Do I generate a QCAD using QCAD source code
Post by andrew » Fri Dec 05, 2014 10:38 am
Please refer to our web site for detailed compilation instructions:
http://www.qcad.org/en/component/conten ... om-sources
725411314qi
Post by 725411314qi » Fri Dec 05, 2014 2:48 pm
Can you give me some instructions detail ? on Windows XP .
