I've recently bought a cople of .dwg maps from OS and they come with the cartisien co-ordinates with 0,0 somewhere in the Atlantic Ocean somewhere of the South-West coast of the Silly Iles. How can I modify this so the the map starts at 0,0 in the bottom right hand corner?
Ordinanc Survey Map .dwg
Re: Ordinanc Survey Map .dwg
I'd do this using cut / paste:
- Select all
- Edit > Cut with reference
- Click desired location of the zero point
- Edit > Paste
- Enter 0,0 in the command line and press enter
- Select all
- Edit > Paste
