How do i open files from QCAD 2?
I have installed qcad v. 3 , but when I try to open files .dxf from QCAD 2 the program says that it is not possible. I have tried to open files and also to import files. How can I do?
Re: How do i open files from QCAD 2?
Thanks for your report.
- indicate the operating system you are using and version thereof
- indicate the exact version of QCAD you are using (3.?.?, see Help > About or QCAD > About QCAD)
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
- if there is an error message, indicate the exact message
Please be as specific as possible in describing your problem, so we can help you efficiently, thanks.
