Linetypes.
GeorgeG
Linetypes.
Post by GeorgeG » Thu Oct 15, 2015 7:35 pm
How does one change line types, width, colour, etc in 3.9.8?
Any help appreciated.
GeorgeG
Re: Linetypes.
Post by andrew » Thu Oct 15, 2015 7:58 pm
Entity attributes (color, line type, line weight) are usually controlled by the layer you draw upon.
You can also set these attributes per entity if you prefer:
View > Property Editor
Select one or multiple entities and change the color, line type, etc. as desired:
Screen Shot 2015-10-15 at 20.39.42.png (77.52 KiB) Viewed 7022 times
GeorgeG
Re: Linetypes.
Post by GeorgeG » Thu Oct 15, 2015 8:41 pm
Thanks for replying.
OK, what if I want to use different linetypes on a layer.
EG: hidden lines, center line.
Re: Linetypes.
Post by andrew » Thu Oct 15, 2015 8:51 pm
GeorgeG wrote:OK, what if I want to use different linetypes on a layer.
You don't.
Layers are primarily used to assign a 'meaning' and visual attributes to entities. Perhaps this post from the tips and tutorials section is helpful to understand the idea behind layers and blocks:
viewtopic.php?f=47&t=3736
GeorgeG
Re: Linetypes.
Post by GeorgeG » Thu Oct 15, 2015 9:59 pm
Well... I can in LibreCAD.
Re: Linetypes.
Post by andrew » Thu Oct 15, 2015 10:11 pm
Yes, of course, also in QCAD (for example using the property editor). But it's highly unusual and certainly not the recommended way of working with a CAD.
