On page 32 in the ebook it show on the wall layer
nice thick lines. How do get lines to be that thick?
Wayne
[Edit: Topic moved to correct forum]
Wall Thickness
Re: Wall Thickness
Hi Wayne
In the layer list select the layer to edit and change the line weight as you see fit.
Re: Wall Thickness
Note that even 2mm might be very thin in the model view if you are creating a floorplan.
The line weight is mainly relevant for printing. A 2mmm line is always printed on paper as 2mm thick, also if you print at a scale of 1:100.
To see how your drawing gets printed, you can switch to print preview:
viewtopic.php?f=47&t=3317
