What can I do with "Auto close polylines"
Post by Husky » Sat Jan 30, 2016 10:14 am
I played around with this new tool "Auto close polylines" - but honestly - till now - I haven't understood how it works ... :oops:
If I have an open polyline - select this polylines - and use this tool I get prompt the message "X polyline(s) closed". Great - but the Property manager tells me it is still an open polyline and I can't see any changes in my drawing - what happens and what is the benefit of this new tool?
Re: What can I do with "Auto close polylines"
Post by andrew » Sat Jan 30, 2016 5:03 pm
If you're not planning to process DXF files further, it's probably not very useful. Anyway, here's the online reference manual for the tool:
http://qcad.org/doc/qcad/latest/referen ... eAutoClose
Moderator
Post by Clive » Sat Jan 30, 2016 6:08 pm
This tool, I think actually helps when laser cutting.
I've noticed less little points when etching surfaces!
I'll need to have a better test and see :wink: .
Post by Husky » Sat Jan 30, 2016 8:29 pm
andrew wrote:If you're not planning to process DXF files further, it's probably not very useful. Anyway, here's the online reference manual for the tool:
Ok - understood. From time to time I need to prepare dxf's for cnc milling / engraving etc. but right now I don't see a benefit for me to covert geometrically closed polylines into a logically closed polyline - maybe something what i need later ... :shock:
Thanks for explanation!
