If I have drawn a rectangle on layer #1 and want to move it to Layer #2 how do I do that?
What is the sequence ?
Moving an object to a another layer
Re: Moving an object to a another layer
Select the rectangle / check the Property Editor which will show you the actual Layer and change it to what ever Layer you need.
