Save As and Open Crash
Posted: Fri Oct 26, 2012 8:17 pm
by pdimick
I am running Qcad 3.0.0 on Windows 7 Home Premiun SP1 -- 32 bit
When trying to open or save files "Not Responding" error is displayed and I must force a shut down. Are there any known issuses.
Thanks,
Paul
Re: Save As and Open Crash
Posted: Fri Oct 26, 2012 8:47 pm
by Clive
Hi pdimick and welcome
A few questions
Are these imported large files from another CAD program or does this happen when for example you create a draft yourself in QCAD?
If its not too confidential are you able to attach a file for testing?
Posted: Fri Oct 26, 2012 11:08 pm
by pdimick
Hi Clive,
Glad to be onboard...Thanks.
It happens when I create a simple draft.
It is happening in two instances:
1. I cannot open a file in the "Open File" option. I can only open by clicking on a desktop icon or from recent items, for exapmple.
2. I cannot save a file in the "Save As" option
Both instances cause the system to to go into a "Not Respond" mode and I am forced to shut down Qcad.
I am attaching a sample draft
Best Regards,
Posted: Sat Oct 27, 2012 11:27 am
pdimick:
- Does the file dialog show at all or does the crash occur before that?
- Do you have any external drives attached or network shares enabled?
I can imagine that an external drive or network share might stall the file dialog while trying to mount or connect.
This should not cause a crash though. Maybe you can also try to let it hang once for a while to see if the dialog is shown eventually.
Thanks for any additional information you can provide.
