Rulers
Posted: Mon May 05, 2014 8:09 am
by Frank60
In 3.4.7 the rulers seem to disappear in new files at grids greater than 1 mm.
I have not found a way to get them back again.
In existing files it works OK.
Is there some setting involved?
Thanks,
Frank
Re: Rulers
Posted: Mon May 05, 2014 5:42 pm
Hi Frank - thanks for mention this.
I assume that is a Bug and not a setting question - but honestly I don't know it exactly.
This behavior isn't new - it occurs since a couple past updates and it's displayed in my application as a ruler bar without units. I'm not able to find a setting which works ...
- Husky-2014.05.05-01.png (6.92 KiB) Viewed 11857 times
@Andrew
Any ideas on this?
Re: Rulers
Posted: Mon May 05, 2014 6:20 pm
by Frank60
Exactly the same symptoms here.
I deleted qcad3.ini (after backup) and then it was all back to normal. Then I compared the files with Winmerge and copied the most important settings over.
It looks to me that there are some incompatible settings in the INI file between recent versions.
Thanks,
Frank
Re: Rulers
Posted: Tue May 06, 2014 8:01 pm
by Clive
Frank
I presume you mean when you zoom out to extents and beyond when the grid spacing is set to something over 1mm instead of the 'auto' setting?
If you draw a point or some other entity (you may not see it once drawn!) and select the Auto-zoom tool - does this bring back the rulers?
Re: Rulers
Posted: Tue May 06, 2014 8:58 pm
Hi clive - check this out:
Old qcad3.ini - growing since many releases ...
- Husky-2014.05.06-01.png (3.87 KiB) Viewed 11827 times
Same Drawing - same zoom but now with a fresh qcad3.ini
- Husky-2014.05.06-02.png (3.92 KiB) Viewed 11827 times
Or ...
Old qcad3.ini - new drawing - no zoom:
- Husky-2014.05.06-04.png (3.88 KiB) Viewed 11827 times
Fresh qcad3.ini - new drawing - no zoom:
- Husky-2014.05.06-03.png (5.71 KiB) Viewed 11827 times
My best guess .... the problem is not located between chair and monitor.
Re: Rulers
Posted: Wed May 07, 2014 8:04 am
Husky: please attach your old QCAD3.ini file, so I can have a look at what is happening. Thanks.
Re: Rulers
Posted: Wed May 07, 2014 8:39 am
andrew wrote:Husky: please attach your old QCAD3.ini file, so I can have a look at what is happening. Thanks.
Sure .... here we are. Thanks!
QCAD.INI
Posted: Sat May 10, 2014 8:54 am
by Frank60
There's a new release 3.5.0: can I safely use the current 3.4.7 Qcad.ini file without having to generate a new ini file? (and manually make all personal settings to the ini file
Thanks,
Frank
Re: Rulers
Posted: Wed Jun 18, 2014 9:31 am
by Frank60
I finally managed to put the finger on a possible cause of this behavior.
If I disable 'Automatically scale meta grid' under App Prefs\Graph View\Grid, the rulers disappear at zooms larger than 100<0 and the have gone in all zooms.
If I then enable 'Automatically scale meta grid', things are back to normal.
Frank
Re: Rulers
Posted: Fri Jun 20, 2014 9:29 am
by Clive
Hi Frank
Thanks for the update, glad to hear things are working well for you now with QCAD
