DWG Object "Band" also known as "Trace" missing
blumi
Post by blumi » Tue Jul 01, 2014 10:19 am
Hello Board.
I have a little problem. We have a lot of small dwg-drawings
that sould be managed in the future by using QCad.
Unfortunately the used dwg-object "Band", also known as
"Trace" isn't displayed in QCad. This object occurs a lot
in the drawings.
Is this object not supported by QCad? Do you have any
plans to support it or will it never be supported?
I added some drawings where the object is used to test
the problem.
It is a important information because if it will not be
supported we can't buy QCad-Pro.
Thanks for your help and information in advance.
blumi
1013.dwg
(83.69 KiB) Downloaded 573 times
1010.dwg
(41.23 KiB) Downloaded 472 times
1005.dwg
(34.23 KiB) Downloaded 459 times
Moderator
Re: DWG Object "Band" also known as "Trace" missing
Post by Clive » Tue Jul 01, 2014 10:39 am
Hi blumi
I opened this with latest QCAD pro, is your object 'Band' shown here?
blumi
Post by blumi » Tue Jul 01, 2014 10:44 am
Hi Clive,
no, unfortunately not. I add a bmp-file where it is shown.
blumi
Moderator
Post by Clive » Tue Jul 01, 2014 11:00 am
Not sure what you 'Band or Trace' is, what CAD program was used originally?
blumi
Post by blumi » Tue Jul 01, 2014 11:05 am
Hi Clive,
the "Bands" or "Traces" are the small filled rectangles
in the drawing. The dwg was originally created with
Autocad R14.
blumi
Post by andrew » Tue Jul 01, 2014 11:08 am
Hi blumi,
No, trace entities are not supported at this point. Support for traces might be added in the future. In any case, I've added a feature request at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1070
Clive: a trace entity represents a filled area with four corners. This was originally used to create thick lines with plotters.
Moderator
Post by Clive » Tue Jul 01, 2014 11:11 am
andrew wrote:Clive: a trace entity represents a filled area with four corners. This was originally used to create thick lines with plotters.
Thanks Andrew, always something new to learn :)
blumi
Post by blumi » Tue Jul 01, 2014 11:14 am
Hi Andrew,
hi Clive,
thanks for your responses.
Trace entities, thats exactly what I meant.
It would be great if the trace entities could be supported.
Thanks anyway.
blumi
Post by andrew » Wed Jul 02, 2014 12:27 pm
Quick update: basic support for trace entities has been added for the next release. This includes loading, saving and simply modifications. This does not include, however, a tool to create new trace entities from scratch.
Screen Shot 2014-07-02 at 13.29.00.png (43.95 KiB) Viewed 11261 times
blumi
Post by blumi » Thu Jul 03, 2014 3:55 pm
Hi Andrew,
so far that sounds great. Maybe the creation of
new traces could be implemented in one of the
next releases after the upcomming release?
This would be great.
Thanks a lot.
Sincerely
blumi
