Problem opening QCAD pro
astridoa
Post by astridoa » Fri Jan 30, 2015 5:20 pm
Hi!
I just bought and downloaded QCAD pro for mac (Yosemite), I need to open and work on a DWG file; a layered map I need to work on and export for publication.
However, I cannot open the file with the pro version. Odd since I had no problem opening the file with the QCAD free version...
I have tried to reboot my computer, and tried on my stationary and macbook.
Any idea how to make it work?
Thanks!
Astrid
Re: Problem opening QCAD pro
Post by andrew » Fri Jan 30, 2015 5:27 pm
Please submit (attach or e-mail) the drawing file for testing, so we can help efficiently. Thanks.
astridoa
Post by astridoa » Fri Jan 30, 2015 5:52 pm
Thanks, the drawing file is very large, 20 MB....
Post by andrew » Fri Jan 30, 2015 5:58 pm
OK. I'll post you a link to a shared folder on our Google Drive you can use to upload.
Can it be that the trial version you previously had was a different version of QCAD? I'm trying to find out if there was a problem introduced in a more recent QCAD version.
astridoa
Post by astridoa » Fri Jan 30, 2015 6:00 pm
Both versions were downloaded today, both are 3.7.7
astridoa
Post by astridoa » Wed Feb 04, 2015 7:43 am
Dear QCAD crew, thank you for efficiency,the problem was solved, the 20MB file was very very slow in charging, that was the problem.
