need help with polyline offset
rray
Post by rray » Thu Apr 23, 2015 9:45 pm
I am probably doing something stupid
rray
Re: need help with polyline offset
Post by rray » Thu Apr 23, 2015 9:54 pm
Forgot the file
B+_Camera_Case.dxf
(943.34 KiB) Downloaded 396 times
Post by Husky » Fri Apr 24, 2015 3:25 am
Hi rray,
please check the shape which is used as base for the offset - there are incorrect corner transitions which will cause a such unexpected offset shape.
rray
Post by rray » Fri Apr 24, 2015 2:15 pm
I am not able to see the problem you are showing me
The file attached is the original
I used explode to get a polyline
Advice appreciated
bottom.dxf
(108.35 KiB) Downloaded 386 times
Moderator
Post by Clive » Fri Apr 24, 2015 3:55 pm
For something very orthogonal, why was it drawn using the spline tool, is this a file not drawn by yourself?
The underlying problem is that the shape to start with is a spline! I would redraw it using line or Polyline tools instead, then offset to the margin you need..
rray
Post by rray » Fri Apr 24, 2015 4:49 pm
No I did not draw this
Thank you
Post by andrew » Tue Apr 28, 2015 8:57 am
The root cause of the problem seems to be that the explosion tool interpolates the spline as one whole curve which results in these beveled corners if the original spline has sharp corners like the one in this example.
I've fixed this issue for the next release by interpolating splines piecewise. This guarantees that corner points are retained. I've attached the result of the fixed explosion tool for this file.
bottom_exploded.dxf
(126.24 KiB) Downloaded 385 times
rray
Post by rray » Tue Apr 28, 2015 2:06 pm
That looks great
You put a lot of work into making it easy for us novice
Thank you
Post by andrew » Fri May 08, 2015 9:14 pm
The problem with exploding splines with corners and straight segments should be fixed in the latest release QCAD 3.9.2.
