Commands stuck - BUG
Rtech
Post by Rtech » Thu Jul 23, 2015 5:37 pm
qcad pro 3.9.5.0, win 7.
I noticed a few commands stuck - do not respond.
The latest one, is the "orthogonal". When I click orthogonal and try to change the degrees, the box with the value doesn't respond. It happened too many times. Or if I click the basis line it doesn't respond, so I clicked many times, then a series of lines appeared placed after a while!
Rtech
Re: Commands stuck - BUG
Post by Rtech » Thu Jul 23, 2015 6:38 pm
I just found out that this is a BUG related to 3.9.5 version.
I instaled 3.9.4 version on a different folder (without uninstalling the later) and it WORKED, NO PROBLEM!
EDIT: Installing in a different folder without uninstalling the other version is NOT recommended, the other version doesn't appear on "Uninstall a program" in control panel and even if you click on the uninstall in "Programs" you have to point it to the "uninst.exe" file itself on the installed folder -otherwise it can't find it.
Post by andrew » Fri Jul 24, 2015 10:12 am
Thanks. This seems to be caused by the recent update to Qt 4.8.7. I will revert to the good old Qt 4.7.4 for the next Windows release.
Post by andrew » Fri Jul 24, 2015 10:15 am
Post by andrew » Fri Jul 24, 2015 3:52 pm
QCAD 3.9.6 (unter Windows based on Qt 4.7.4) has been released and should fix this issue.
